Well this happened...
Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
  1. #16
    Member 2wheel's Avatar Array
    May 2014
    Michigan
    159
    Quote: Originally Posted by eGo View Post
    Damn You! lol I totally missed it, thought that was part of your sig.. haha Glad you're able to keep her
    Wow I missed it too until outcast99 said to look at the bottom of the post. Glad she is getting fixed.
    I will make sure I keep a large following distance to keep this stuff from happening.
    08 SXT 3.5L RWD
    Mods: Pin striping, Air silencer removal, XE Ryder's Chilly air intake mod, DiabloSport InTune, Mopar hidden hitch, BC Racing coilovers with rear Air Lift Air Spring kit, SPC upper front A-arms, winter grill block, Big Bully intake & catch can
    Future plans: R/T front brakes
  3. #17
    Not low enough... outcast99's Avatar Array
    Sep 2011
    Oregon
    414
    And shiny stuff
    And other Mods
    Demon Lights
    2005 Dodge Magnum RT with 300c SRT clip Bagged on 22's
  4. #18
    Member truckzilla46's Avatar Array
    Jan 2010
    Iowa
    909
    Man that's a nice booth! Looking good brother!
    Api Forged 392 660rwhp/680rwtq comp 428 cam p/p heads titanium pushrods psi springs Api 85mm t/b Magnuson s/c 11.6 psi Shr Trans FTI 2800 t/q dss 1400hp driveshaft/axels Qaife diff 3:55 gears Api brace BT catchcan/caps and wing Carbon by design hood/pillars/int kit moroso overflow/ p/s reservoir canton s/c tank Custom c/f sub floor box with kicker L7skicker 1500rms mono amp Spohn rearend kit BC coilovers Billyboat cat back LTH PLX gauges 3g half covers abs cover fuse box cover
