Please help rim questions
Results 1 to 3 of 3
    Newbie Array
    Feb 2018
    2
    Can I put 22 inch custom ram rims on 2005 magnum rt
    Newbie Array
    Jan 2017
    7
    Sure, why not? Even if the lug pattern is different you can always buy adapters.
    Sent from my iPhone using Tapatalk
    Newbie Array
    Oct 2018
    2
    Yes you can, but you will need to cut the extra threads off the upper control arm in order for the tires to fit.
    Sent from my SM-N950U using Tapatalk
