Engine Shutting Down
Results 1 to 2 of 2
    Newbie Array
    Aug 2019
    2
    Brief history
    Bought an 06 RT back in January. It had shutting down issues and I got a good deal because of it. I replaced all the sensors, cleaned and checked all the connections with no changes in the shutting off issues. I took it to the dealer and they told me that it was most likely the ECM but couldn’t be certain. I bought an ECM from the Car Computer Exchange, installed it and the car ran fine. I then swapped out the interior with an 06 SRT 8 Charger interior and harness. Everything worked fine except for the duel zone AC system that came from the Charger. The car ran and drove fine for a couple of months and then started shutting down again. This is where I’m at today. Thanks in advance for the help.
    Newbie Array
    Oct 2019
    United States
    3
    Indeed one should save their engines from getting it shut down.
