Radio stays on when shut off and doors open
Results 1 to 5 of 5
    Newbie Array
    Oct 2019
    3
    Looking for some ideas what might cause this problem. I shut the car off and the radio and the dinger stays on even with the door open, I have to jiggle the ignition o get it to go off. Any ideas,
    Member bjkeky01's Avatar Array
    Mar 2009
    39
    I have the same issue. My display says the key is still in the ignition even when I have it out. I’ve replaced the whole ignition key assembly still nothing. I did change the settings in the display to change the time out to turn everything off. You may want to do that so you don’t kill the battery. But if you figure out please let me know.
    Newbie Array
    Oct 2019
    3
    I was thinking off changing out the whole ignition unit, been thinking out might be the black box attached to it, but since you tried that, and it didn't work. Not sure how to go about changing settings. How do you go about doing that?
    Array
    Warren, MI
    18,999
    Dodge just changed out my ignition under a recall, maybe check that out....Got two new keys too!!
    Mar 2009
    39
    What year is your magnum? I saw a recall for 2008 but mines a 2007.
