Suspension lowering information
Page 4 of 4 FirstFirst ... 234
Results 46 to 60 of 60
  1. #46
    Member Da Animal!!!!!!!'s Avatar Array
    Jun 2011
    Queenz
    908
    Thanx Fireman, i hit Greg up, so i'm waiting on him 2 get back to me, Good Looking!!!!!
  3. #47
    Jun 2011
    Queenz
    908
    Got Tein drop springs on the mag, did the SRT-8 complete front end suspension, and did new shocks& struts all around. Mag rides GREAT!!!!!!!!! Will post pix soon!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  4. #48
    Newbie Array
    Aug 2011
    10
    Quote: Originally Posted by DemonSVT View Post
    Something that needs to be addressed is the fact that any alteration from stock is going to require the ability to significantly adjust caster and camber specs. The stock setup was already beyond its ability to do this (i.e. cradle adjusts were even tried!) and thus the “wander” problem was such a problem. (pull right anyone) Fully adjustable LCA’s (~$400/set) or centric LCA bolts are a must in order to give your Magnum a decent handling setup and passable tire wear.
    Also matching your dampers to your new “lowered” setup is a must if you want predictable and competent handling. Stock dampers on a lowered setup will be working out of their effective range. This is far from ideal in the least. Lowering just for the sake of lowering is a “show” queen’s job and is HIGHLY NOT recommended! Real drivers need not apply.
    Demon you were talking about pulling to the right,well my 05 rt has had this problem from the day i brought it,had it in for 2 wheel alignments but still have the pulling problem,they even turned around the tires which are directional tires so they were running backwards and this did help but didn,t like the idea of running directional tires the wrong way,so now I,m back with the pulling problem,any help out there?,really love the car and plan on keeping it a long time
  6. #49
    Array
    U.S.A.
    18,841
    There's a TSB (technical service bulletin regarding this issue. The alignment specs were changed. to correct the pull. I had the same issue with my '05. I had it done to mine, problem solved.
    Here is the TSB from the factory. Print it out and take it to an alignment shop. Have them follow these instructions.
    http://www.wkjeeps.com/misc/LX/TSB_3...SB_0200205.pdf
  7. #50
    Newbie Sick-Evolution=SE's Avatar Array
    Aug 2009
    9
    Well, my friend runs Kspots on his BMW and he said there fantastic and he knows other guys who run those on other various brans of cars. So your best bet would be to call them up and ask the Ksport people specifically.
    Quote: Originally Posted by CaptainBly View Post
    I am seeing lots of brands out there.
    Any news on the following brands?:
    DZ___________
    KSport_________
    Tenzo_________
    D2________
    Are they just cheap knock offs or can they give a good ride?
    Hidden Content Dodge Magnum 2.7L V6, 20" Torq Thrust II's, graphite grey.
  8. #51
    Newbie UNFUKWTHABL's Avatar Array
    Jun 2011
    Woodridge Illinois
    5
    Thanks for the info,have been wanting to lower my .357 wagon for awhile and finally got the extra cash to do so again thanks for all the info
  9. #52
    Array
    U.S.A.
    18,841
    No problem! You're welcome.
  10. #53
    Newbie Array
    Mar 2012
    6
    The suspension elements will be made from light and portable materials, mainly aluminum, that offer much lower unsprung weight when in comparison to placed precious metal. Additionally, these headgear will be associated by higher speedometer bushings, anti-sway cafes and powerful shocks.
  11. #54
    Member TXHEMI's Avatar Array
    Feb 2012
    San Antonio
    138
    Fireman to the rescue again. I have had this issue as well on my 05. Kept thinking maybe it's just me... now I know.
    This forum never ceases to amaze me, keep learning new stuff everyday.
    Texas Hemi - 2005 R/T
    DiabloSport Intune, Airaid CAI & TBS, Flowmasters w/ X pipe, debadged except HEMI / RAM logos, 18 in fumagalli wheels, Kicker sub/amp.. crazy dreams for NEW MOTOR
  12. #55
    Newbie tunes 64's Avatar Array
    Feb 2013
    Southern Vermont
    8
    Hey Gang,
    I have a 2005 Magnum R/T. It has Eibach lowering springs and I'm having a problem with it bottoming out when going over bumps. I carry about 850 lbs of audio/video equipment in the rear. Is there a suspension system that will allow me to adjust ride height, such as air struts, but will maintain load capacity when deflated?
    Thanks,
    tunes64
  13. #56
    Feb 2013
    Southern Vermont
    8
    Sorry,
    Let me rephrase that last sentence. Is there a suspension system that will allow me to adjust ride height, such as air bags, but will maintain the load capacity throughout the adjustment range?
  14. #57
    Array
    U.S.A.
    18,841
    Quote: Originally Posted by tunes 64 View Post
    Sorry,
    With that much weight, I'd say bags.
  15. #58
    Member h8it huh?'s Avatar Array
    Jan 2013
    east bay, cali
    251
    Sorry,
    Yes. Ask around the site. There are some guys with airide on here and I'm sure they'll point you in the right direction!
  16. #59
    Who's on 1st Santi's Avatar
    Array
    Aug 2010
    Vacaville, CA
    7,278
    Sorry,
    I would def go bags and with that much weight go 1/2 lines so u have the force to get up quick when need be
    Sent from my iPad using Tapatalk HD
  17. #60
    Jun 2011
    Woodridge Illinois
    5
    Thanks for the info guys,I'm not looking to get crazy yet just looking to Herr that ugly wheel well space outta there,I got 22s on my '07 and it looks like shit with that space
