Magnum has the shakes...still
Page 6 of 7 FirstFirst ... 4567 LastLast
Results 76 to 90 of 96
  1. #76
    Array
    Warren, MI
    18,999
    I had the same problem with a caliper.. front left, on a Plymouth MiniVan.. After replacing the Master Cylinder, Vacuum Booster, Front lines, the caliper AGAIN. I found the proportioning block was bad... I don't know if an ABS equipped car has one.. but it had a "little bitty" bit of dirt in it causing it not to slide and release the pressure on the front calipers......BUT it was only the Drivers side that kept toasting... GOOD LUCK!!
  3. #77
    Quando omni flunkus moritati. stingrayj's Avatar Array
    Sep 2008
    Hanover, PA
    3,790
    The other wheels seem fine. It's just the right front that is locking up. I know that it is getting fluid to the caliper based on what I did to it yesterday, but it is not relieving the pressure. Which component actually relieves the pressure? Do you think that replacing JUST the caliper will fix the issue?
  4. #78
    Sep 2008
    Hanover, PA
    3,790
    Just installed the new (reman) caliper from NAPA. The caliper itself was blasted and included a new bleeder valve. The kit also came with a new bracket that was painted black with new guide pins (which were sticking) and bolts (which were bigger than the OEM bolts). I chose not to use the bracket since it would look goofy painted black and the guide pins were sticking. The kit also had new clips for the pads and seals for the banjo bolt.
    I reused the OEM caliper bracket (as mentioned above), guide pins and bolts, pad clips, and the dust boot for the bleeder valve (since the reman caliper did not include one). Everything was pretty easy to install. I did not seal off the brake line since it was not dripping much at all. I just let it hang and drip.
    I got everything together and bled out. I put the wheel on and gave it the spin test to see if the rotor was warped. There was a little sticking, but that could be pad transfer. The good news is that the wheel does spin freely now. So far it is looking good!
    I'll update in the morning after I get a chance to drive it on the highway. Hopefully this will be the end of it!
  6. #79
    Array
    Warren, MI
    18,999
    Good Luck brother! you deserve a break!!!!!! I will be waiting here in the morning for the GOOD NEWS!
  7. #80
    Hemi? Noooooooo! gangster wagon's Avatar
    Array
    Jun 2007
    southern utah
    7,347
    No more shakeing MOJO for you!!! Man u need a break from this prob so hope it works out finally!!
  8. #81
    Sep 2008
    Hanover, PA
    3,790
    Given that I am extremely paranoid about every shake, wobble, rattle, or any other possible thing a car could do (including operating the way it is supposed to), I'd say that I am close to resolving this issue. The ride to work this morning was definitely positive. There was a bit of an unsettled bobbling over washboard roads (which we have a lot of around here). I have a times thought I heard a slight rattling sound over such roads which is making me think that maybe the upper ball joints may need to be replaced too. But, it could be my paranoia too.
    There was a vibration, though, and I am quite certain that it is a warped rotor. On long stops from highway speeds, which put a good bit of heat into the rotor, there was a noticeable vibration. The longer you stayed in the brake, the more it would vibrate. However, within about 3 seconds from leaving the stop the vibration would stop. This is an improvement as well. Low speed stops in town did not produce much, if any, vibration. And the reman caliper appears to be operating well with good pedal feel.
    So, eventhough I may still have a warped rotor to deal with, my current assessment of the vibration issue can be summarized like this:
    ...however, I want to see several days of shake free driving before I am thuroughly convinced that the issue is resolved. There's my paranoia again.
  9. #82
    Member lowendboy's Avatar Array
    Dec 2010
    82
    sorry to hear you are having such a hard time with this.
    The best way to check the rotor is with a dial indicator. I have one with a fancy magnetic mounting apparatus. If you can borrow, or buy one relatively inexpensive, this will give you the exact amount of run out that your rotors have.
    http://www.harborfreight.com/media/c...image_4565.jpg
    I own 3 cars and do not believe in turning rotors for these 3 particular applications. However, a hard lesson learned years ago when I would get them turned, that process CAUSED run out, ie warped.
    This often happens from any of these things, dirt or a burr on mounting surface of rotor or lathe, the technician not taking care it chucking the rotor up true, or worse case a warped lathe.
    When you get a rotor turned you have a high rate of success with both sides of the rotor being parallel to each other, however equally important is that those surfaces are exactly perpendicular to the rotating axis.
    ...otherwise you have run out , ie a warped rotor freshly turned.
    Good luck and see if you can get a dial indicator. I use mine for many things. Can't rebuild a differential without one!
  10. #83
    Array
    Jun 2007
    southern utah
    7,347
    Good to hear that it's getting better!
  11. #84
    Sep 2008
    Hanover, PA
    3,790
    Well, there is still a vibration. And it is fully in the brakes. Press the brake pedal and it shakes. Release and the vibration goes away. You can also feel it at 65-70mph without hitting the brakes. It seems like the rotors are warped, but not too bad...just enough to cause a vibration.
    There's also a bit of a light grinding/rubbing sound. I'm guessing that the pads which are "pre-scorched" are now baked/glazed? Will that improve as they wear, or are the pads shot too? Driving around with a seized up caliper is apparent hard on brakes.
    Aside from that, though, it is driving well.
  12. #85
    Sep 2008
    Hanover, PA
    3,790
    The car steers and corners well. It drives straight. And other than the warped rotor it is vibration free. However, there seems to be a general "roughness" to it. It just seems that the car should be smoother than it is. And occassionally over rough sections I can hear a faint knock. So, now I'm wondering if the upper ball joint is also worn.
    Since this is a pricey part, how can I "test" to see if the ball joint is worn?
  13. #86
    Sep 2008
    Hanover, PA
    3,790
    I crawled under the car to take a few pictures tonight.
    Right front brake rotor...
    Drive shaft...(front of car)
    (Rear of car...)
    Support bearing (a few shot since it was hard to get)...
    And then there is this lovely mess...
    Passenger's side...
    Driver's side...
    From back of car...
    Another angle...
  14. #87
    Array
    U.S.A.
    18,841
    My WAG (wild ass guess...Lol) after looking at your pictures is this............
    Your drive-line and drive-line couplers look ok . Looks like outer coating peeling off, that's all.
    Your differential looks like it may have been overfilled when you last serviced it. The vent is on the top of the differential on the side that appears more "wet" with gear oil. Could it be a seal or some other kind of leak?.....Yeah, maybe, but I'm guessing that it's the vent. Oil will seep from the vent if overfilled.....Quite common. Mine looked just like that.
    That brake rotor is messed up! That's the "bad" or "stuck" caliper I'm guessing.
    That rotor looks like it's been "overheated" in areas and looks like "pad transfer" in other areas. You might try resurfacing it and get the caliper rebuilt or replaced.
    You might need to replace that rotor.
  15. #88
    Sep 2008
    Hanover, PA
    3,790
    I was planning to have the differential flushed and filled during my inspection in April. After seeing the leak I was wondering if I should wait that long? Are you saying that this is "normal"?
    The right front caliper seized up completely which, I believe, is what caused the over heating issue. I am an "easy breaker" as much as possible. I prefer to slow down early for a stop light and time the green so that I don't really have to come to a complete stop. So, I'm pretty sure that the bad caliper is the culprit here. I just wasn't sure about the pads. Are they toast? Will they still be useable? I am getting a little bit of squealing out of the right front at lower speed stops.
  16. #89
    Array
    U.S.A.
    18,841
    As far as the pads go..........Definately replace that set (rt side). Maybe the rotor too.
    The oil on the differential may very well be coming from the vent which is right above the rt. axle (see pic) I'm thinking it is
    If it is, there's nothing to worry about. It just means that the gear oil level is a little high.
  17. #90
    Sep 2008
    Hanover, PA
    3,790
    Looking back at my pics, it does look like the oil is originating from the vent area. I was just concerned that it may be leaking to the point of having nothing left in it.
    Dropping more money into the "money pit on wheels" is really getting old. As much as I hate the idea of replacing the less than a month old brakes, it looks like I don't really have a choice.
