Hello my good people,
I'm a big do it yourself-er but it's hard to do so without knowing the location of certain items. I've been looking to see where is my starter located at on my Magnum, i can't see it from the front so i'm guessing it's either under or behind the engine, I was trying to get some outside help before i try to lift the car.
Background: The car died on my wife while she was driving, the battery reads good, the car clicks no turn. All lights come on so I'm guessing it's a bad solenoid or starter.
I took the battery out and I hooked up the jumpers the car and it had a steady click so my engine wont turn it just clicks so i'm hoping the issue lies there.
If you have any other inputs please enlighten me, it's been a while since i've changed out a starter on a vehicle just hard to trace the negative terminal since the batter is in the back of the vehicle.
Replacing the starter on a Magnum is a complete PITA. I'd never do it again. It's located just behind the steering column underneath the car. Have you alternator tested first. It may not even be the starter.
Hello my good people, I'm a big do it yourself-er but it's hard to do so without knowing the location of certain items. I've been looking to see where is my starter located at on my Magnum, i can't see it from the front so i'm guessing it's either under or behind the engine, I was trying to get some outside help before i try to lift the car. Background: The car died on my wife while she was driving, the battery reads good, the car clicks no turn. All lights come on so I'm guessing it's a bad solenoid or starter. I took the battery out and I hooked up the jumpers the car and it had a steady click so my engine wont turn it just clicks so i'm hoping the issue lies there. If you have any other inputs please enlighten me, it's been a while since i've changed out a starter on a vehicle just hard to trace the negative terminal since the batter is in the back of the vehicle.
I’m having the same issue what was the problem with yours?
