Has any one had a problem with the transmission line leaking? If so what route did you take to repair. Any one do it yourself? A week after replacing the electric fan the trans cooling line between metal and rubber started leaking. Like to get some feed back on this problem. Heard it was quite prevelant. thanks for any infol. Your road dog.
not a prevalent problem that I know of , however it should be a quick fix if its the rubber sleave fitting. Could be you kinked the line or there its corroded.
