So I have read countless threads on how many issues people have with engine/alternator noise after installing aftermarket stereo systems. I dealt with mine for a while but it drove me to the point of insanity and I finally found something that actually worked. I will post detailed pics tommorrow when theres some good sun light out. What I did was replace the ground wire on the drivers side that goes from the shock tower to the exhaust manifold. After replacing that ONE wire with a 4ga piece the noise went completely away. I no have absolutely no engine noise and it was way more simple and cheap than all the other things I had done to correct the problem. I did every test and fix you can imagine, exotic RCA's, moved ground points, upgrade factory battery ground, ran H/U ground to the battery, powered the H/U from the lighter and with the PAC unit, ran the RCA'S on the drivers side(as far as possible from the main power line hat goes along the length of the passenger side) along with the speaker wires and replaced(just swapped temporarily with known working devices) all of the system components one by one and couldn't catch a break. So after reading a thread over on LX forums about some trying to sell some of those ricey (HYPERGROUNDING kits) I decided to change the weaker looking grounds under the hood and the first freaking one I replaced eliminated this freaking noise. Anyway I'll post pics of the culprit and the whole sytem in the morning, I hope this will help some of you out there who have just given up and learned to live with the noise!:beerchug:
