Where is it supposed to mount? Mine's just hanging from the harness. Is it
Supposed to go In front of the radiator or tucked into the engine compartment somewhere?
It's supposed to be up by the radiator somewhere.
In front of the rad? thanks!
Here's the low down.........
Underside of the metal bumper, off center (more toward the passenger side) there should be an "L" shaped clip that the flat part on the sensor slides into, it's supposed to lock with a small tab.
As long as in it UNDER and not behind the bumper it should pick up air flow from the lower grille area of the fascia.
Thanks! Mine was just hanging there in front of the rad so I clipped the christmas tree clip into the plastic air-dam thing. Now I know it's supposed to go on the bottom of the bumper. Next time I have the fascia off I'll put it where it belongs.
