Hey all, I just got an 05 Magnum, AWD,5.7 . Only has 50,000 miles and super clean. I couldn't believe it when I saw it. Need AWD for winter. Now it's spring so time to make it fast.
Installed a KN cold air intake and replaced the suitcase and mufflers with flowmaster 40's. Easy stuff.
Now for the questions...
What headers do you recommend? (the awd is throwing me off)
Are high flow cats really necessary? If so, what should I get?
What fuel pump do you recommend?
What cam do you recommend?
What gear ratio do you recommend?
Should I replace the spark plugs? Which ones?
I have a SC1 procharger with about 10,000 miles on it in my truck. Should I use that in the Magnum?
I have the next 3 weeks to get all this done. Then will be back to work...hopefully. Don't want to spend all kinds of time on research. So I'd rather just have someone else experienced and knowledgeable just tell me what to get.
