I have a coolant leak. See pic below. In addition (see pic)...sometimes the red light on the dash comes on (not sure what it means) and the car temp. stays cold even after the car has been running for a while and it doesn't blow heat (sounds like a blockage somewhere, faulty sensor or both?). Sometimes if I cut the car off and restart it....the temp goes to warm? Any ideas on how to fix these problems?
It looks like the coolant air bleeder is bad (common). - 2006 DODGE MAGNUM Coolant Air Bleeder
I'd say that your coolant level is low which can account for the heater issues.
Replace the air bleeder and make sure that the cooling system is filled. Your issues should been resolved.
Thanks a million!!!!....and I really appreciate the link. Looks like an easy fix. I'm glad it won't cost me an arm and leg to repair.
