Hey everyone.. new to the forum..just got a 05 RT 5.7.. I noticed the cooling fans don't engage with the engine and ignition off which makes the engine compartment stay warm for a while...my question is are they supposed to come on around 220° or do they even come on at all...
I have an 06 Magnum R/T. I had everything looked over to try to eliminate any problems. I took a trip across the desert in August and found out that my fans were not working. One should automatically turn on anytime the a/c is on. The other fan should work off of the engine temp sensor. I ended up having both fans & motors replaced and have not had a problem since. I'm not sure if the fans should come on to reduce heat soak when the warm engine is shut off, but you want to make sure that both fans are working.
