1 - 13 of 13 Posts
This WAS the "last change I will ever do"
Got tired of polishing out the scratches in the plexiglass.
So I decided to go back to the solid top with the amps completely hidded like before. (old pic, still have to cut new carpet)
Now for the new
Take a panel $8, Mirror $10, 2 sets of door edge protectors $5, 2 LED strips $20 and some adhesive $3 ($46 total)
Take mirror out of frame and cut the door edge protectors to dress up the mirror edges, cross drill holes to hide wires, mount LEDs and you get this.
Hook up portable car jumper to test
Paint the panel black and mount the stuff
Test it out in the car(remember still hav eto recover)
And turn off the flash (camera makes it look darker than it really is
__________________
They call me Destroyer
that looks pretty darn slick! O i cant wait till I get money saved to do the things i want to the back of the MagWag!
Discussion Starter · #6 ·
Now that's nice! I hope the booming of the sub doesn't shake the glass loose.
Time will tell hahah, if it does, it will def break the mirror. It was only $10 at WallyWorld. Then I will use the mirror tabs. I didnt this time to keep it clean looking. I used a whole tube of the adhesive haha. Giving it the weekend before I go nuts with the boom.
That is a really sweet mod and very original as well.
Discussion Starter · #12 ·
Today's updates
Added piano hinge and cabinet handle ($15)
Instead of using a prop rod, going to use a replacement rod for the cover (only for showing and it will be black) dang sun
Now with some carpet down, not glued yet
Still have to wire up the lights
1 - 13 of 13 Posts
