JUS WONDERING IF ANYONE HAS DONE THE MPG TUNE?? IM RUNNIN 93OCT CAI TUNE AND GETTING OK MPG 13-14 ( WITH MODERATE FOOT IN FIRE WALL:drive:) BUT USE MY CRUISE WHEN EVER POSSIBLE. IM PROBABLY GUNNA PULL THAT TUNE AND INSTALL THE MPG TUNE BUT STILL RUN 93 JUST IN CASE I WANT TO SWITCH BACK AND FORTH. BASICALLY JW IF ITS WORTH MY TIME??,, OH AND ITS FRIDAY BIT**'S:headbang::banana::friday::049::beerchug:
It'll take 5 minutes to change tunes. You need to decide for yourself whether or not it's worth it.
where's my airbrush??
its my understanding that running the economy tune, while still running 93, is not a great idea. Not sure about the science behind it, but was under the impression that the extra octane was wasted (so spending unnecessary $$ on higher grade fuel) and that since that extra octane was not used, it was allowed to go through into the cats and eventually cause problems there. Bill?
I just put in 150 miles with the Intune MPG tune using 93oct and was showing low 16's mpg on EVIC. I was getting the same with the Diablo tune so I switched back. The 93 CAI tune resulted in the same as what you got (13-14). Did not see a real performance difference between the Diablo & CAI tunes except MPG. I did have MDS shut off, throttle boost 20%, & shift firmness on with the MPG tune. Not sure how much that affected MPG's?
