1 - 16 of 16 Posts
Pulled from my blog @ http://iamkraze.com
So I have a new car.. it has a nice stereo, but I wanted better. I found out that you could get a nav dash for around $200. For one, this is way expensive for a small peice of plastic..and the double din requires you to have to use not one but two adapters to get a double DIN to fit. This in my opinion was alot of border and alot of money. So like the DIY guy I was, I decided to mod the existing one.
Keep in mind, this isn’t fully done.. its a rough fit, and will be molded better once all the car audio parts arrive. I am missing an adapter still so the dash cant go on.
For starters, heres the dash I have:
Notice the knobs are sticking out on the radio? Yea.. that doesnt help in the ease of mod department.
I ordered the
used to install in the navigation bezel to work from.
I took out the tray, cut the middle piece out with a dremel (per the metra instructions) and then cut the top and bottom part of the bezel off. This left me with this:
I cut right to the adapter part that bolts into the car. This will make it more flimsy but it should still hold up well inside the car. Notice how the screws are in the plate.. this isnt how its supposed to mount but it angles it up a bit to allow for better placement in the dash. I also plan on enforcing this better from the back inside the dash. (L brackets to rest on.)
I then had to dremel the dash to the appropriate size. I trimmed the left and right sides so the metra would just fit in snugly. The bottom I had to sand down even onto the heater panel. This was cutting it very very close.
Notice the top of the heater lost a bit of the plastic that holds it in. Its alright since its screwed on.
I then fit the radio in place to test fit:
It doesnt look the best. So at this point I needed a bezel. Since the dash is chrome, I went to the hardware store and picked up some chrome strips for cars. I found this will look pretty good.
Thin chrome for the top and bottom:
Thick chrome for the sides:
For those interested in how deep the dash is, its about the same as a standard DVD:
I will add pictures of it finished next week when the PAC-Audio Can steering wheel control mod arrives. Also I will show where to moun the addon modules I have (bluetooth, serius and USB hardrive)
"INSTITUTIONALIZED"
Congratz on the install-I did a couple of thoze modified DDIN bezelz for sum peepz.I like the fact that tha screen sitz higher than tha NAV bezel version!!!!!
good work. I will be doing this with in the net couple weeks
Discussion Starter · #8 ·
Look into my eyes
No drag. I was actually inspired by this post. I didnt want to have to do all the repainting and such however. Any knowledge is good knowledge when it comes to this stuff :)
Cool. Can't wait to see the finished product since your taking a different route already.
Looking good, glad to see people taking the time to DIY. There isny a better feeling than saying "I did it myself". A kind a bummer is that to the average person, they look stock and dont know the work it takes. But it is nice to see their face when I used to show them the stock photo to finished photo ahha.
Chip Foose once said "the best mod is so subtle, that people have to wonder if it is stock or not".
Discussion Starter · #12 · (Edited)
Thankfully I am a DIY guy all around. I assume by the end of this it wont look stock, but it will be so much more cool :)
People SHOULD try this, a NAV bezel is 200, and I am sure a standard bezel isnt.. so even if you mess it up, going back to stock isnt that expensive.
!!!GOBEARSGO!!!
any updated pics of this...???
1 - 16 of 16 Posts
