1 - 1 of 1 Posts
Doors are pretty simple. Phillips screws, plastic rivets.
Roll the window down.
There is one screw in the door handle area under a lil plastic rectrangle.
The plastic rivets are easy, take the key and push on the center, DONT push the center all the way in or you will be taking the weather barrier off.
With the centers pushed in, just pull the rivet out.
With all the fasteners out, pull the bottom off and lift up, this will disconnect the top of the door panel.
Then disconnect the door lock linkage retaininer.
Disconnect the power window switches and tadaaa! It's off.
1 - 1 of 1 Posts
