So the great state of California has your general smog inspection that states if the check engine light is on, you cannot pass smog. Well after the computer spits out the info, it says that:
Coolant Thermostat (coolant temp. below thermo. regulating temp)
EGR Sensor - A Circuit High.
My question is, how difficult is it to replace the egr on the V6, if that is the case, and what is with the thermostat? Is it just remove and replace with the correct one? The car is running within the correct temperature range.
Any help or suggestions would be appreciated.
