1 - 12 of 12 Posts
VinylDecals.com
I am thinking about getting a 300c in the future. I was thinking about getting it the same color as the magnum. Would we be able to swap front ends without having to go to the dealer to get additional parts?
I know people have swapped front ends on the magnum, but that was getting parts from the dealer. Do you think this would be possible?
you would have everything you needed if you swapped the parts from one car to the other. you will have to cut some of the front light connectors from the cars and swap them also. the headlights and side lights have different connectors between the two cars.
VinylDecals.com
What about if the 300 has HID? Are the ballasts easy to remove and connect into the magnums' wiring?
if you have a magnum and want to put the 300 front end on it, you are going to need
fenders
hood
fascia
headlights
headlight washer fluid nozzles/hose
radiator support
these parts should let you get the swap done
1 - 12 of 12 Posts
