Got a question about aftermarket gear ratios... searching various sites I seen gear sets for AWDs but for only for the rear axle none for the front axle. My understanding is that both front and rear axle ratios must match. If this is true why can't I find gear sets for the front axle.
Next I wonder if someone installed a set of 3.91 gears but also used the 8 speed ZF transmission to take advantage of the higher 1st gear 4.71 vs. 3.59... but also to offset the 3.91s with the .67 final drive of 8th gear.
I'm not saying that I'll be doing either one of the mods to the "MAG PI" but more curiosity.
Thanx,
Matt
a) I don't know
b) If the gears set are the same physical SIZE, wouldn't you just buy two sets of the same RATIO... One for the Front and one for the Rear?
c) See "a)".
