Hello all,
The following is a list of parts I recently ordered (control arms are blown out along with ball joints/TREs) and am curious if anyone has pointers/help/tips for my install this weekend!
MONROE 172248 Strut Assembly
MOOG K80996 Ball Joint
MOOG RK620178 Control Arm Upper
MOOG RK620177 Control Arm Upper
MOOG RK620258 Control Arm Lower
MOOG RK620257 Control Arm Lower
MOOG K80823 Stabilizer Bar Link
MOOG K80822 Stabilizer Bar Link
SKF 6504007 Spindle Nut
TIMKEN HA590030 Wheel Bearing & Hub Assembly
BENDIX D1056 Brake Pad
MOOG ES3571 Tie Rod End Outer
MOOG EV80702 Tie Rod End Inner
POWER STOP AR8358XPR Rotor
The only tips I have found so far is --
1 -- Front suspension needs to be under load before torquing down the fasteners
2 -- If the mounting bolt is ribbed, loosen the nut and not the bolt
If anyone can chime in on a few tips it would be extremely helpful with my install!
Thanks!
Thanks!
