Hello, I'm T, just got a 05 magnum rt w 48k miles. The dealer replaced the rack and pin, ball joints, and serpentine belt... when I pulled off the check engine light came on, turned around, it was a o2 sensor.. I have some questions already. Hopefully you guys and gals can help.
I'm a gm man, dodge is new to me ( besides a 2006 Chrysler pacifica lease I got in 2005)
So question 1, why the heck does this engine take 16 spark plugs my goodness!!! Lol. I had a 2004 gp Gtp comp g before this car ( giving the Gtp up so I can get the rt) the Gtp takes 91-93 gas. Does this car take just 89, or is it ok to use 91 in it?
It does this thing where, it bings, then all the gauges go crazy, and then the gauges drop... like the car has been cut off??? Idk what this is. It's done it 2x so far. If I'm driving the car, it'll keep running, just the gauges are dead like I cut the car off, then the esp light comes on. If the car is running idle, and the gauges go nuts, the rpm gauge revs up and down, then boom, car cuts off... I don't get it, but like I. Said, its only done that 2x
Also, the steering is pretty stiff. Is this normal??? I know its a heavy car, but the wheel is pretty stiff when trying to turn it.
Is it hard to do a tune up on 16 plugs? Are they all located on the top of the 5.7?? I can't tell.
Lastly , I never changed brakes on a car w double pistons, is it any different from the norm? Just use the c clamp, and the old pad to reset the piston, or is there more to it w this car.
I appreciate any feedback from anyone, thanks!!!!!!!!!!!!!!
