1 - 1 of 1 Posts
2006 Rt 5.7
The fuel pump behind driver just started humming non stop and the wiring is getting hot. Has anybody else came into this issue? I ordered a new fuel pump and should be here tomorrow. Will replacing the fuel pump fix the issue or is there something else i need to do. Thanks
Also I have seen other magnum owners running into the problem of a value in the engine letting go and destroying the whole engine. Is this a common thing and what can i do to prevent it from happening?
1 - 1 of 1 Posts
