Would these rims fit a 2005 Magnum R/T with RWD?
Lugs: 5 x 114.3mm (5 x 4.5")
  • Backspacing: 6.77” and 7.32”
  • Offset: +45mm and +52.5mm
  • Center Bore: 70.6mm
From Silver 2 Sexy Bullet
Wheel size? The offset may not clear the brakes or fenders if you are going with a something other than a donut wheel.
I believe if you go with a concave wheel you will be fine. My only concern will be brake and strut clearance. It may fit without hitting the strut but will be close. A comfortable offset for a 9" wheel is between 10 and 25 for the Magnum. Going with a 45mm offset will move the wheels closer to the strut tower. If those are wheels you must have, consider getting a set of 1/2" spacers (at minimum) to go with them. RTs don't have the Brembo package so you can get the same size spacers for the front and rear without issue. Hopefully this helps.
Appreciate it, not must haves but were a good deal for a set of new performance pack mustang wheels and tires at $600
Not bad.
