Hi New to the forum.... I did the swap from 2.7 to 3.5 on my 05 Mag Se.... the engine that I swapped came from same year car but it had ABS now Check engine light is on because speedometer and odometer aren’t working..... Is there any way to reprogram or remap computer to get CEL out and not look for ABS module that isn’t there
Swapping engines on these vehicles are hard. I wish you luck but you need to reprogram the computers. Not sure if it is possible. Sorry man. Search for threads on 3.5 to hemi swap. There used to be someone that could get that to work and they may be able to give some advice.
