I learned that you can take the silencer out in 30 min and it gives you a lot better sound.
Its a super easy job that i did between dinner and going to the movies
Just take the bottom plate lose and your right wheel cover on the inside.
The bottom two clamps. take a long extended wrench and undo just one bolt.
It falls out almost by itself.
When you do that you can also take out the bottom little plastic piece that closes the radiator off.
Only take the bottom one off. This gives a bit more cold airflow into the engine.
I am now working on extending the air filter box all the way to that part next to the radiator.
This way the cold air comes from the front of the grill right into the air filter box.
Like a hidden shaker intake.
If this all makes seance in my dutch English
