My cats are shot and looking to replace them with high flow cats. Is it worth the money or should I just get the cheapest cats I can find! I have magnaflow glass pack for exhaust. Is cutting them out an option or I need them for back pressure?
I went catless mids from JBA. They make high flow cats too. About $450. The cats have their own separate pipe which is flanged so it doesn't need to be cut out.
Mid Pipes
Depending on where you live, many if not most, high flow cats will not pass emissions testing. If that's an issue for you, you be better off replacing them with emissions compliant converters.
Nope not an issue. Where would one find the best price for jba high flow cats. So far 514 is the best I found
