I have an 05 magnum with the factory 6 disc player radio "rak version" which also plays cassettes. Well the cd player stop working so now im replacing it with another factory 6 disc player radio "raq version" which does not play cassettes! I heard its just simple plug & play...
But how do i remove the radio and the bezel????
Please help me... If i have pics of the removal thats even better!
open ashtray and pull at the bottom of the center bezel. It feels like its going to break but it wont. It will give way and just work your way around the bezel till its off. Then each wire connector has a release, push on the release and pull the connector off. The radio has 4 screws , remove those. Reach around and undo the connectors and antenna.
http://www.lxforums.com/board/showthread.php?t=11322
Texas Magnum
I've never disconnected the battery when dealing with the deck, but I suppose it wouldn't hurt. Of course, whenever dealing with something run a power line other than w/ a harness I would recommend disconnecting.
