I recently bought an Intune for my 05 R/T and I am running into a problem using it. I can write a tune but if i try to do anything else afterwards like go into data logging, it will not recognize it is still connected to my vehicle. Also, I went from the 91 tune to the Diablo tune and it i started to throw CEL and BAS lights on the dash. I tried clearing them but the tuner wont tell me what the codes are as it says no ECU found. The only things I wanted to change and try on on the Diablo tune were the Shift firmness, Autostick settings and the shift points. When the tune threw all of the warnings up I tried to write the factory tune back on and start over. When I tried to write the factory tune, it fails and says the Shift points, Autostick and shift firmness cant be reset and will not reset back to the factory tune.
I've searched on here and on LX to see if anyone else had this same problem and it seems like I am not the only one. From reading it seems like no one has a real fix. Some suggest to pull Fuse #11 but that seems to fix the warning lights. At this point I would really like to reset the factory tune and send the Intune back...... Anyone have any suggestions or can point me in the right direction??
