1 - 10 of 10 Posts
Hey y'all new 2006 magnum rt owner here and i'm just curious if anyone of you have or are planning to lower your car and if there are any problems if you have already. I've been hearing that if lowered the vehicle rubs/bumps the fenders alot. Dealership suggests not to lower it because of this problem they have had with their show models. I currently have 22" sittin on 35" a JBA exhaust and JBA titanium coated headers. The highest mpg I've rated was 23.4 mpg and that is keeping it under or about 2000 rpms.
VinylDecals.com
First off, Welcome to the site. We'd love to see some pics of your ride.
What exactly does that mean? You have a 35" Overall diameter tire or you have a 35 series tires? What is your exact tire size?
I think you should be fine if you are running a 265/35/22 tire or something close. That is the tire size I am planning on running and I plan to put air ride on my Magnum.
sorry it's the series, but my rims are pretty wide and stick out somewhat past the fender wall
Major Mag Nut
Then you may have some problems with rubbing if they stick out at all. I've got the eibach Pro-kit on my car and haven't yet rubbed a fender, knock on wood. If the wheels fit correctly you shouldn't have issues.
VinylDecals.com
What is the width and offset of the wheels your are running?
sorry guys been pretty too busy lately to get on the computer, anyways Steve my wheels are 22x 9.5, the wheels alone have a 3 inch lip not sure about the offset and if you are looking into getting some headers shorty's are smog legal in Cal long tubes are not, neither are mid pipes. they don't make a high flow cat yet for this vehicle to my knowledge.
Major Mag Nut
Check with the sites' supporting vendors for the high flow cats. I know that High Horse Performance has them listed on their site for $459.99.
Check the off set
I will say that you need to check the off set of the rim. When I got my first set of wheels for my white awd, the tires stuck out from the body. It looked like a remote control car. If you like it that is cool. But if you change the off set of the rim, it will solve that problem. The lowering kit is good, and I will say that it is a very smooth ride. Just a little noisey from the tire. For the reason that there is not a lot of tread. Ground Fource Lowering kit is GREAT. Kris
1 - 10 of 10 Posts
