I had this problem Sat. but pulled fuse 11 out for 30 sec and cranked right up. I tried today no luck? Do you guys think i can unplug battery to get to reset? Any info appreicated!!!!!!
If the noise is coming from the fuse box it may be a relay. But most likely the noise is coming from the starter, the gear is popping out but not spinning. This could be because not enough juice in the battery or the starter is going out.
I had this happen on ONE of our magnums and thought it was the battery too; battery checked out fine, but somehow my ground wire was loose; tighten that up and good to go. Good luck; I found OUT these cars do require some serious cranking power.
Related Threads
Custom Dodge Magnum Forums
859.8K posts
43.1K members
Since 2005
A forum community dedicated to Dodge Magnum owners and enthusiasts. Come join the discussion about modifications, classifieds, performance, troubleshooting, maintenance, swaps, and more!
