Had#14 fuse fry itself into the panel. It's not coming out. Need a new panel. Anyone have one or info about one...would be greatly appreciated. Also...found one on line...some subtle difference numbers. Vendor code spot on though. It came out of a 2005 Chysler 300. You think it will fit the Hemi with no issues?
Vendor code doesn't mean anything. Same vendor made all of them, 50 different part numbers. Part numbers have to match. Can most likely be 300 or Magnum but will need to be outfitted the same. SE, SXT, SRT8. And be 2005 only most likely. 05 & 06 were odd builds and pretty much year specific. The computers were Gen3. 07-10. Were Gen4 so probably not even close.
The connectors just plug in on the bottom. Be careful when releasing the locking bars. There is a double locking clip on each. You can easily break the locking clip if not done properly.
If you just need the upper plastic, you can maybe just swap it out off of one that is identical. The top plastic isnt critical but the circuit board inside is. Might be able to do a Hybrid version.
I can probably get you one if I have a part number to match up.
