1 - 9 of 9 Posts
I'll start off by saying this is both my forst post, and my first time trying to mod Maggie, I screwed something up while I was trying to find the running wire with my volt reader. Now my driver's side blinker isn't working. I got the new lights on without a problem as it is a fairly simple installation, but I can't figure out how to wire the Halos properly, and now I have a broken blinker. Any advice on where to go from here would definitely be appreciated. Thanks
Discussion Starter · #2 ·
UPDATE: I managed to fix the blinker, it just shorted out from the volt reader i used. I still cant figure out where to wire in the LED and Halos. I'd really appreciate some advice from anyone whose wired their own Halos before.
Thanks.
Meet Celeste
What is your problem exactly? Are you having trouble of getting the wiring inside the car? I don't have halo's but I have lights in my grille. I wired them to the back of the engine bay where there is an opening in the firewall to get the wires inside then tapped into my center console outlet and wired them to a switch...I think I have a write up, I'll check on that for you.
Do you have the projector headlights or the halo rings ? Are you tyin to connect the LEDs to their own switch, or make them work by using your headlight switch ? I've done both installations, but I need more info before I can help.
Discussion Starter · #6 ·
I'm using Spyder projector headlights with Halos. They also have a row of Phillips Lumiled LEDs. I have the positive and negative wires all spliced but the problem is that I don't know where to connect them. I'm trying to get them to work on my current headlight switch.
GooN
You need to tie them into the parking lights.. Then whenever you turn on the parking and or headlights they will come on..
eGo
The wires should be reds to reds, blacks to blacks, browns to reds. Those were the colors of my wires. My brown wire was the turn signal/parking light. Connect em just like that, plug em in, and they'll work just like your stock headlights.
1 - 9 of 9 Posts
