1 - 14 of 14 Posts
need help have an 05 rt need any and all info on towing up to 3500 lbs as far as I know car does not have tow pack asumming I dont anyone know what I need to do? thankis in advance
What up from Northwest Florida
check out uhaul they are around $200 or so or google it and you can find them.
You'll need a class II hitch at the least.....Class II hitches are for loads of up to 3,500 lbs. GTW and 300 lbs. tongue weight.
Nivomat, self leveling rear shocks might be a good idea also.
Welcome to the site.
from a FOUR MAGNUM family in North Carolina.
Welcome from the MotorCity, Michigan!!
Be sure to Check out Welcome to 3GCUSTOMZ.COM!!! for your Modding needs
or give me a PM and I will try to help you out!
Just a sampling of what we DO!
UAS Air Suspension
Vertical doors from VDI
Quality Fiberglass from Karl's Kreations
Exhaust systems from Blastin Bobs
Big Bully intakes and Catch Cans
Full line of SLP products
Katzkin Interiors
DMH Cutouts
Danko Reproductions
AAC
R1 Concepts brakes
Engine dress-up sheet-metal, ABS Cover, Coolant Cover, Engine cover inserts, Firewall inserts!
We also offer CAD design and Water Jet Services
Glenn
welcome man!
i'd do a class III hitch, just incase, too big is never a bad thing
put some nice brakes on it
and the self leveling shocks as bill said
and depending on the trailer you gotta haul
maybe a brake boost controller
i know thats a must on trucks
and A MUST
to make it sound good under a load
you will need a bada** exhaust
i think that should be top priority
Welcome from the Florida panhandle. I put a 3500 Hidden Hitch on my SRT. It wasn't too bad, although, the directions said 45 minutes - there's no way - I had to drop the exhaust on both sides.
. It wasn't too bad to install, although, the directions said 45 minutes - there's no way - I had to drop the exhaust on both sides.
1 - 14 of 14 Posts
