SilverBack
Forgive me if this is a stupid question, but the Pac C2A-CHY has a 4 channel RCA output, so am I correct to assume that if i have one Mono amp connected to it, I am able to connect another mono amp?
Asking because I have one amp connected to it running two 12's, and was thinking of adding another amp for two other 12's sitting in my garage. Here is the Pac Audio installation diagram :
I am a computer.
You are running subs off of this?
From what I can see the device outputs a full range 4 channel signal. That is why you have 4 RCA's. Front left/right and rear left/right. I am surprised you can run subs off this output. What make/model amp are you using?
According to the diagram you posted, yes you can run two 2 channel or mono amps or one 4 channel amp. They should be full rage signal so you would either need some type of signal processor to get just the sub frequencies or a sub amp that has the processor/filter built in.
