My passenger window just stopped working or basically I cant get it up now. Is there a way to manually put it up or some kind of hack because im not in the best area for just leaving my window down & funds are low for a couple days any advise would be great.
2006 Dodge Magnum R/T AWD
this is just off the top of my head
So the switch stopped working, have you checked for voltage? Swap out a rear switch but make sure they are both connected, see if that works. Other than that you would have to get inside the door to disconnect the glass from the arm to manually put it up.
