i have a 06 sxt it will not start the first time i turn the key but it will start the second time i work late at night in a bad part of town im worried one night it just wont start this started to happen after i had a new transmission put in i dont known if that has any thing to do with this problem,thank you
Magnums Rule....
So it wont even turn the engine over on the first try?, do you get clicks?
Sounds to me to either be a bad ground or the battery is going bad. I'd check the connections on the battery for tightness ~ ALSO check the positive and negative terminals under the hood.
