I have a 2005 Dodge Magnum RT HEMI with a problem. When I quickly accelerate the car will try to do a hard stop until I let off the gas pedal. The engine is not bogging down it's just like I slammed on the brakes. An alarm will go off from the dash with no "warning" light. I immediately let off the gas pedal and continue with a slower acceleration. I checked for a trouble code but found none. Has anyone ever experienced this with their car? Any information would be appreciated. Thanks
Any takers on this? I put it up on 4 jack stands.
Put it in drive the rear wheels turn. The front ones won't turn until you gas it. Then the left side turns and stops. The right side started to turn and then stops.
I also have these codes.
P3401 & P3449 I'm not sure if the codes are related or not. See my full post to see it's behavior. It's just like what Wonderzone said.
