1 - 11 of 11 Posts
When I turn on my ac the center console air conditioning ports barely let any of the air through. Could there be a clog? Any ideas
My favorite animal is a Ribeye -Fran Lebowitz
Did you ever have high flow from the console outlets??? Or are you now noticing the low flow??
I think the low flow is normal, mine does it also.
Bob
I think that's normal as well.
I can't imagine that anything has found it's way in there to block the ducting.
The only way to be certain is to dismantle!
I notice a slight difference if I switch to the "feet" only setting. But most of the time those vents do not put out much air.
Sent from my magnum.
There are seperate floor/foot outlets other than the rear center console ones that are under the front seats and lay flat on the floor.
That might explain that.
Thanks y'all. I'll see what I can do to get it flowing higher.
nothing can be done. thats how it is on all LX models. who cares lol, I never drive on a back seat
I understand the wish for higher flow to the rear. And I haven't looked into it. Booster fans to the rear may be a help.
I'd like to know a fix also.
1 - 11 of 11 Posts
