21 - 29 of 29 Posts
Good info for the BCR.
How did the light bar install go? Would like to see it.
Sorry no one responded to your initial post. But like you said better late than never :)
Nice Install and Thank you for posting up the pictures!
So you have a mini-compressor for making adjustments anywhere? Nice!
Discussion Starter #23
Mikey,
The compressor is the little black box at the center of the spare tire well. From completely deflated to full 25psi takes about 5 seconds. It's pretty cool :) You're supposed to set the desired pressure before you load the car so it stays at the proper ride height. But you can still add pressure it it feels too soft.
Very cool write up. After I put my TowHitch in I will be adding this set up to my stock springs. Or should I get a set of Nivomats?
I think I should use a rider hitch even though I am stock height in back.
I will be towing an early Camaro about 3400lbs.
Discussion Starter #25
Sorry for the late update on the light bar. Haven't had time to go out and take a proper photo, but here's a shot from my iPad of the car in the parking lot :p I still need to properly mount the switch inside the cab. Thinking I'll put it next to the shifter for quick on/off manipulation since my hand is always over there for the autostick.
Discussion Starter #26
Fred,
The airbags will be helpful regardless of which shocks you use, but the Nivomats are awesome. I'm disappointed that they can't be used with lowering springs. With the Nivomats, you won't need the air bags.
21 - 29 of 29 Posts
