1 - 1 of 1 Posts
I wrecked my Magnum and am now replacing the entire right rear independent suspension. I have everything removed except the last arm which is snapped. The bolt holding it to the car seems impossible to remove without cutting it because there isn't enough room to back it out without hitting the body. Should I just cut it and replace the bolt and put it through the other side? Or is there a way to remove this bolt without cutting it that I don't see? The nut is on the left and then the bolt will have about 1.25 inches to move which wouldn't even be enough to get the arm out of there. See picture below.
1 - 1 of 1 Posts
