I bought a REQ + RSC unit (part no. 05064920AG in Canada anyways - non-nav) and was wondering if anyone knew what each of the pins on the back were for? The right side is marked "A", is grey, and has 22 pins (12 lower 10 upper). The left side is marked "B, is white, and also has 22 pins (12 lower 10 upper). The center connector has 10 pins (5 up/down) and is for the "UConnect" system. I have been able to find that the B6 and B7 pins are for the video out, but can't seem to find any other info. This Unit came from a system with the amp, but since the HU is the same for all applications, I can change or add wires to the connectors to match the pins for the basic functions. The unit is from a 2008 Jeep Wrangler JK, but is the same unit that can be found in:
Dodge: Avenger 2008 - 2008
Dodge: Journey 2009 - 2009
Dodge: Nitro 2007 - 2009
Jeep: Liberty 2008 - 2009
Jeep: Wrangler 2007 - 2009
It bolts right in to the stock mounts on my 05' Magnum (have to cut the bezel) and I know what the wires in my Magnum are, so I just need to know what the pins do on this unit so I can mate them up. Any help would be greatly appreciated. Thanks.
Picture is not of my HU, but the same (ignore the "C" graphics)
Thread here: http://www.custommagnums.com/forums/audio-video/15507-video-out-harness-needed-req.html
List here:
Other PINs on REQ
Radio C1 - Gray 10 way
Hands Free (U-Connect)
1 18LB/DG LEFT AUDIO OUTPUT
2 18DG/LB RIGHT AUDIO OUTPUT
3 -
4 18DG/YL MICROPHONE FEED
5 -
6 18DG COMMON AUDIO OUTPUT
7 18LB/DG MICROPHONE IN (-)
8 18OR/GY SENSOR GROUND
9 -
10 -
Radio C2 - Gray 22 way
Audio
1 18RD FUSED B(+) (I.O.D.)
2 20WT CAN INTERIOR BUS (-)
3 -
4 -
5 -
6 -
7 18GY/OR AMPLIFIED ANTENNA FEED
8 18GY/LG LEFT REAR SPEAKER (+)
9 18GY/DG LEFT REAR SPEAKER (-)
10 18DG/LG RIGHT REAR SPEAKER (+)
11 18DG/GY RIGHT REAR SPEAKER (-)
12 18BK/WT GROUND
13 20WT/OR CAN INTERIOR BUS (+)
14 -
15 -
16 -
17 -
18 -
19 18DG/VT RIGHT FRONT SPEAKERS(+)
20 18DG/YL RIGHT FRONT SPEAKERS(-)
21 18GY/VT LEFT FRONT SPEAKERS(+)
22 18GY/YL LEFT FRONT SPEAKERS(-)
Radio C3 - White 22 way
Rear-Seat Video Montior
1 18GY/LB AUDIO RETURN 3
2 -
3 -
4 -
5 18GY/BR VIDEO SIGNAL 1
6 18GY/YL VIDEO COMMON 1
7 VDO-VIDEO SHIELD 1
8 18GY/LB VIDEO SIGNAL 2
9 18GY/YL VIDEO COMMON 2
10 VIDEO SHIELD 2
11 18GY/OR AUDIO RETURN 2
12 18DG/VT AUDIO LEFT 3
13 18DG/YL AUDIO RIGHT 3
14 -
15 -
16 -
17 -
18 18DG/TN AUDIO LEFT 1
19 18GY/VT AUDIO RETURN 1
20 18DG/WT AUDIO RIGHT 1
21 18DG/LB AUDIO LEFT 2
22 18DG/DB AUDIO RIGHT 2
Discussion Starter · #6 ·
Do you happen to know what the other pins do? Also, am I correct that the function of the CAN INTERIOR BUS directly relates to Navagation? If so, since I don't have Nav, it shouldn't be an issue. The only other info I really need is what pins are for accessory (ignition) power (assuming #1 is battery power), dimmer for display brightness, and if the #7 amplified antenna feed can be used as a remote turn on for an amp. Hope that makes sense lol.
