I'm sure you have all read the "How To" posts about this so I won't elaborate on my install...
I picked up some 2.5" OD x 2.25" ID adapters, exhaust clamps, the bumper eyebrow kit and got to work...
Fairly basic install, although fabbing up the factory heat shield mounts took a little bit of thought...
I picked up some rubber grommets, vinyl washers, and some panel plugs and epoxied up my own mounts...
Needless to say the factory heat shield works perfect on the 3.5L tank...
I also found it easier to work on everything with the bumper removed...
Enough with the talking and on with the pics...
Exact look and feel I was hoping for!
Also, no hacking or welding needed...
One last thing, the factory sound of the duals is nice!
Hope this helps anyone looking to do this mod...
Edit - side note, if you plan on using the factory heat shield, be prepared to drop the rear end of the drive line...T60 torx
