If anyone has done this swap, will you please email me at [email protected]? I'm trying to buy a set of stock RWD 18" R/T wheels and tires ( new). I need to know if these will fit my 06 magnum SE with 2.7 RWD, I hear the bolt pattern may be a bit smaller than all the other magnums and disc brake and wheel off-set may not work either. ANY HELP OUT THERE???
Major Mag Nut
On the RWD models all should have the same bolt pattern 5x115 and the same offset requirements. The AWD have different offset as well as the SRT-8 . If you run SRT-8 wheels you will need 3mm wheels spacers so they don't rub on the suspension.
