My 06 mags a SE and the dash bezels are black instead of the brushed silver in all other magnum models, does this plastic bezel snap off so I could maybe have it plastic chrome plated? Also, the bottom two steering wheel spokes don't have the silver inserts either, can these be added to my stock steering wheel? Thanks again for any info........... email [email protected] or post message
Major Mag Nut
The gauge bezel will come off, but be careful if you break it it will set you back a couple hundred for a replacement.
Here is the dash bezel
Here is the hole that the steering wheel inserts leave when popped out. Take a thin screwdriver and go on the outer edge of the insert then pry out. When inserting make sure to put the inner side in first under the horn cover.
