So mine seem to not to want to let me fix them.
Can i jack up one side at a time or do i need both sides up?
It's just the two bolts and pop off the cover put the new one in?
Also I keep hearing about lube. I have the moog ones do I need some extra lube or something on those?
Thanks
Go to the auto parts store and get some bushing grease. Get the front of the car off the ground (both sides) so the sway bar isn't loaded and replace the bushings. It should be pretty easy to do.
Your gonna fight the bar if you try doing one side at a time. Once you get the car on stands, it's pretty simple. Oh and instead of the grease I used teflon tape, just wrap the bar under the bushing.
