1 - 20 of 72 Posts
Okay people, here is the first draft of the Ultimate CM How To. Please, please, please post here if you have another article that you think should be added to the page. I will update this as soon as I have more articles to post! :beerchug:
Welcome fellow Magnum enthusiast! If you have a question about your Magnum, here is a list of some of the most popular answers! If you don’t see an answer you are looking for, send me a PM and I will help you out! Enjoy!
**General & Site Info**
How To: Reputation and Rep Points
How To: Post Pictures
How To: Navigate Multipaged Threads
about: Members Map
How To: Edit Screen Name Display
How To: Create A Legal Signature
about: Conversions
**General Magnum Info**
How To: Get Your Build sheet
about: Magnum TSB's & Recalls
How To: Get a Free Owners, service Manual (.pdf)
Fluid capacities and recommendations
complete-list of trouble-codes
or try this
Diagnostic Trouble Codes (DTC)
**Exterior/Styling/Painting**
How To: Seal OEM Headlights
How To: Tint Taillights
How To: Convert Headlamp Switch to Automatic
How To: Mold Danko Grill and Spoiler
How To: Relocate Rear Hatch Switch
How To: Install HID Low Beam and Fog Lights
How To: Install Vertical Door Kit
How To: Paint Brake Calipers
How To: Remove Front Fascia
How To: Wash Your Car w/o Water
How To: Remove and Paint Emblems
How To: Remove and Reinstall Tail Lights
How To: Polish Your Head Lights
How To: Prep and Paint Under Hood Componets
How To: So you want to remove your rear wiper
How To: Install a Charger SRT rear difusser
about: Not All Microfiber is Created the Equal
**Interior/Electrical**
How To: Remove Door Panels
How To: Run 12v from Firewall to Cabin
How To: Fill Center Dash Pocket
How To: Install Mopar Illuminated Door Sills
How To: Check OBD2 Codes
How To: Replace Window Regulator
How To: Remove Center Console (05-07)
How To: Remove and Replace All Interior Bulbs
How To: Run Signal Power To Side Mirrors
**Performance**
How To: Port a V6 (3.5L & 2.7L) Throttle Body
How To: NAG 1 Dipstick and Temperature Measuring
How To: Recharge K&N Airfilter
How To: Install a Catch Can on a 5.7L
How To: Adjust fan speeds for a 180 thermostat w/DSP
How To: Tranzformer shift kit settings
about: Intake Guide
about: Exhaust Guide
about: Resonators and Mufflers
about: Diablo Sport Predator
Exhaust video/sound clips
**Mechanical**
How To: Spark plug change on a 2.7
How to: EGR replacement on 2.7 & 3.5
How to: EGR replacement for 5.7
How to: Replace oil pressure sensor on a Hemi
How To: Replace NAG1 electrical connector
How To: Check NAG1 fluid level & temperature
Parking brake shoe replacement -
http://www.lxforums.com/board/f62/how-replace-emergency-brake-shoes-126095/
Crankshaft position sensor replacement 5.7 -
http://www.lxforums.com/board/f88/crankshaft-position-sensor-replacement-173432/
**Audio/Video**
How To: Install Monitors Into Factory Headrests
How To: Install Overhead DVD Monitor
How To: Install Subs and Amp w/OEM Radio
about: MyGig Information
**Suspension**
How To: Replace Outer Tie Rods
How to: Change tension struts
How to: Spring & damper installation
How to: Rear sway bar install
about: Lowering AWD
about: Wheel and Tire Guide
about: LX Suspension & lowering basics
about: Wheel Offset
Info: Suspension torque specs
**External Threads**
Charger Forums: How do I...EVERYTHING!
LX Forums: Free Mod List
How To: Bed Brakes After Changing
How to: Bleed your brakes
Performance calculations
Parking lock-out instructions (pink thingy)
MDS on indicator light installation how to
How to change parking brake shoes
**Videos**
How To: Prep and Tape Before Traveling to an Event
**MUST READ**
Charger Forums: Stay Out of the Fuse Box
I Piss Excellence.
WOW I wish this whas here when I first came to the sight. Please keep sticky.! I will look and see if I can find another threa. How do you want us to prepare a new thread I know copy and paste but do we need to PM you or just post it in the thread??????
PM or post here...I will get it on the list!
Danger,Death,Destruction
Nice work
Discussion Starter · #11 ·
Thanks everyone!
all links work and take you to the thread that it says. Glad to NOT see any outside links and only CM threads.
Thank you for checking my work. A bean for you sir...and yes, that was what my plan was. Stay with only CM threads unless there is something that everybody should know and its on a different forum. CM ONLY!
Nice work Floyd, it's STUCK!!
Thank you sir!
Mr. Entertainment
flloyydd im glad your apat of this site!!! u deserve cmom!!!!
Discussion Starter · #15 ·
Can do...that thread is why I thought CM needed one like this.
Nice work a bean to you!!!
Thank you!
Thanks brotha...just centralizing info
LX Aficionado
AWESOME AWESOME Work man... looks great... for your consideration I offer a helpful LXF link for cheap/free mods:
FREE MOD's LIST!! - LX Forums Modern Mopar Muscle
Something I looked at a lot, might not quite fit in this thread, but who knows...
again, this is great!
Discussion Starter · #17 ·
External Thread section added
1 - 20 of 72 Posts
