just bought an 05 r/t. heads we rebuilt in Jan 2019, I'm getting a tick on drivers side around the 3rd cylinder back can't be heard at idle only about 1500rpm and gets louder as rpm increase ...where should I start with diagnostics?
First check for a leak at the exhaust manifold gasket or a possible crack in the manifold. Get a cheap stethoscope from Harbor Freight or on line. They are very cheap and excellent for finding noises. Next check for lifter ticking. Common on the 5.7 Hemis . As long as it is a tick and not a knock, you should be fine.
What do you usually do in your free time? I think you still need time to rest, there is a small suggestion for you to try the krunker you will feel more comfortable and have more fun waiting for you, try and see this miracle. Have a good day!
