I have a 2005 Magnum SXT with 3.5L V6 24V High-Output Engine and a 4-speed Automatic Transmission. I am getting a rumbling vibration when I take off from a standing start. It continues as it shifts through the lower gears and almost disappears in the higher gears. Taking her to a tranny shop on Monday, and would like to get some ideas what to expect when I take her there. Anyone have some input?
You could have a contaminated transmission fluid issue, the torque converter could be having problems or worst case, transmission issues. A transmission shop should be able to help. Be weary of a shop that wants to immediately tear into the transmission or recommends a rebuild without a thorough inspection. If it were my car, I'd have the transmission serviced first. That should include a full fluid and filter change which can either help the issue or eliminate the possibility of contaminated fluid.. If that doesn't help, then you need to consider further investigation.
To give you some kind of idea on cost; Tee's DEMON car had the transmission, (4 speed), completely rebuilt and added transmission cooler and it cost us $1600.
This is an older thread, you may not receive a response, and could be reviving an old thread. Please consider creating a new thread.
Related Threads
Custom Dodge Magnum Forums
859.8K posts
43.1K members
Since 2005
A forum community dedicated to Dodge Magnum owners and enthusiasts. Come join the discussion about modifications, classifieds, performance, troubleshooting, maintenance, swaps, and more!
