1 - 8 of 8 Posts
I have the Eibach 5.66030k arms ajustable.. for sale if any body else looking to install, $225... NEVER PUT THEM ON MY MAG, Brand new!!!! hit me up....
Anyone know the size of this insert on the bottom of the ball joint stud? Kept the nut on loosely to keep it from separating violently but now its stuck (stud turns with nut).
Need to hold the stud still to loosen the nut all the way.
EDIT:
6mm for reference
One tip I can give for accessing the rearward facing nuts is to use a spark plug wrench with a flex joint. Made it WAY easier to get the angle needed with the socket. On the Passenger side there is bracket that is in the way. I think it has a 10mm bolt on it. I took that off and moved it out of the way and found the access was much better.
1 - 8 of 8 Posts
